You may ask: "why 2xMPL instead of 2 additional SRM6"? Because in solo / PG you never know what you will end up figth against, so better be prepared with a little bit of ranged damage if the enemy team is death balling hard and you can't hug or backstab freely without taking return fire. _ The main weaponry are the 4xSRM6 at point blank range. If you can't get close enough to apply damage without spread or is too risky, you can harass with MPLs or add some pinpoint-ish damage with those additional 2xMPL. Also, thanks to -10% cooldown quirk, MPLs will reload faster than SRM6, so you can shoot SRM first and then apply MPL for additional damage while SRMs are traveling to the target.
