I'm trying to figure out what to do with my Founders Atlas, but the meta isn't on the side of Brawlers, so here's my try : Use the larges on the approach, the SRM/AC20 at close range, and the pulses when you can/zombie. Optimized version :
Not a bad build, I run almost the same except instead of CT MPLAS I have a third LLAS. Played about ten PUG matches two days ago and batted average 400 damage with a peak at 960. It can be done but it is harder work then ever given the slow speed and high damage output nowadays.
I think u can perform better if u downgrade the MPLas to MLas, redistribute the ammo to drop C.A.S.E., and use those 2.5 tons to upgrade the SRMs to ArtemisIV-linked, and to increase the legs armour. I prefer A4-linked in SRM6s cause, at 250 meters, i dont feel im wasting missiles if i aim anything tinier than an Awesome. Also u can even pinpoint the SRMs at 150meters, but without A4 its the range whr it starts to worth to fire.
My version, I really like SRM4s though 33% of the SRM burst is missing. dual MPL in the torso (more pinpoint especially since you're so slow). AMS version = run STD330, remove DHS, add 0.5t armor and AMS.
5/5, Love this build Got 1k damage with it the other night. no consumables. My build is has just a couple minor differences though. Mainly just changed the engine.
2LL+2ERML are still a solid ranged weapon base for whatever you put around it for damage. Lbx20 made its way into many of my (mostly hot) atlas builds.
