Casual AS7-KR "Ymir" (1xHGR 1xHPPC 4xERML TC2 STD300) +Alt(STD340)
Thread in 'Kraken' started by Excalibaard, Apr 22, 2018.
  1. Excalibaard
    4,303
    938
    219
    HPPC + HGR combo, supported by 4ERML in a relatively cool package!
    Faster version also possible:
  2. Nekromanteia
    Nekromanteia New Member
    Tried this with the TC2 STD300 and I liked it, is it advisable to maybe downgrade the HPPC for MRMs? I tend to dive in headfirst into the fray xD
  3. Excalibaard
    4,303
    938
    219
    MRMs is a different choice for a different playstyle, that's more about spreading as much damage as
    possible. I also do HGR+MRM40 for that reason, but this variant is more about pinpoint pressure at slightly longer ranges. HGR+HPPC is basically a dual AC20 in terms of pinpoint&damage, but with better projectile speed and range.
    Thanks for the review!
    Nekromanteia and CarloArmato like this.
  4. Excalibaard
    4,303
    938
    219
    STD300 version is interesting BTW, I've built it and it seems very manageable in heat!
    EDIT: I didn't look well enough and thought the STD340 version was the base build ;p Apparently STD300 version was the real original build! (need some sleep)
    Nekromanteia likes this.
  5. Nekromanteia
    Yes, it's a very cool build for the Kraken! Pun and literal meaning intended. Alright I'll stick to the HPPC then, thanks!
  6. Nekromanteia
    Changed to 5* as it is still amazing, and I accidentally gave a 4* previously!
  7. Guyver
    Guyver New Member
    just bought hero pack with the steam sale and tried the ST300 build... loving it!
  8. MayTag
    MayTag Junior Member
    If you upgrade to LFF armor you can fit a STD 355 in for 58.8kph
  9. Excalibaard
    4,303
    938
    219
    You also lose some DHS which are nice to keep the HPPC + ERML firing as often as possible. I personally find the higher weight STD engines generally not worth the tonnage.
  10. ShiverMeRivets
    ShiverMeRivets Active Member
    82
    I have not tried the Kraken, but I run HGR+HPPC+2MLs on Orion Protector and it is a lot of fun. Firing the HGR and the HPPC together is extremely satisfying (i.e., charge up and release both). Won’t get you very high damage numbers, but a lot of components destroyed and kills for the little focused damage.
