AWS-8R Splatsome A (4x SRM6+A, 2x LLas, STD300)
Thread in 'AWS-8R' started by UntamedZer0, Apr 17, 2013.
  1. UntamedZer0
    UntamedZer0 Well-Known Member
    215
    The A is for Artemis
    I had this mech laying around and was about to sell it. I had it set up for LRM boating but I don't particularly enjoy LRM boating. Plus it had been a very long time since I set it up to splat. So long that I don't even think Artemis was around yet.
    Sooo.... this mech probably shouldn't have been done which means it needed to be.
    There is a bit of a C.A.S.E experiment going on here so ammo location is subject to change. The quad 6s can unload the ammo fairly fast at least.
  2. Blagg Zear
    Hi there,
    what about this approach:
    Blagg Zear
  3. robertmw1988
    robertmw1988 Junior Member
    Removed AMS. More SRM Ammo + CASE. Changed DHS position to help protect Laser for that last little bit. Plus once Lasers are gone, who cares about 1 DHS.
  4. Aylek
    This is a very strong approach even nowadays with Clans running rampant. I'd prefer more cooling for a mech like this as it doesn't has the speed for hit-and-run tactics. Shutting down in the middle of opponents won't end well.
    Small modifications on the OP's build:
    Additonal ideas:
    LPLas + MLas can be fired in conjunction, but this obv. costs some range. The weight reduction allowed to mount some additional DHS though, which are crit padding the right arm. As a last change I rearranged the armor to be very front-heavy, as this should be a mech for the first line.
