Meme BAS-B 'Alpha Asp' (2xcGR, 2xcHLL, 4xcHML, cECM)
Thread in 'Blood Asp Omni Builds' started by Remover of Obstacles, May 16, 2018.
  1. Remover of Obstacles
    Remover of Obstacles Star Lord
    963
    367
    169
    High alpha - will need heat skills to avoid internal damage on most maps.
    Less alpha, but more range and lower heat per alpha.
    If you can get by without ECM, you can use the Prime and gain an extra ton of heat sink, ammo or armor
    and pick up -5% Heavy Laser Heat Gen.
  2. Remover of Obstacles
    963
    367
    169
    Trial run with all Prime omnipods for quirks.
  3. Excalibaard
    4,271
    931
    219
    More Alpha! 2x2x10 > 2x15
  4. Excalibaard
    4,271
    931
    219
    Slightly less alpha, but the tonnage and DPS gained from switching GR to cAC10 is significant for more cooling and more armor (can also do LBX10 for crits).
  5. Remover of Obstacles
    963
    367
    169
    I think I see where this is going.
