1. Welcome to MechSpecs!
    --Cheers, the MechSpecs Team.
BJ-1X Red vs Blue (2x LPLas, 6x SLas, XL280)
Discussion in 'BJ-1X' started by Excalibaard, Feb 5, 2014.
  1. Excalibaard
    Excalibaard ComStar - First Circuit Staff Member
    3,154
    506
    219
    Yep. Green pewpew is too mainstream.
    Not likely to be viable, because you're so short range. The LL+ML build has more of that range, as well as more damage and speed. Even pure ML would be better, if TOO MAINSTREAM AND UNORIGINAL!
    If you like the colors red, blue and a bit of wubwub, this is for you.
  2. epikt
    Mouep, that's the problem. Why not something like that?
    (maybe it's already been done)
  3. Excalibaard
    3,154
    506
    219
    only a 2xLPL 2xML build has been posted
    Green is not a creative colour! 1:49
  4. jc4hokies
    jc4hokies New Member
    The 2 LPL 6 SL build is what I settled on and should not be underestimated.
    First, LPL and SL are the most heat efficient energy weapons available. It normal mode, firing just the LPL, it runs at 66% heat efficiency. In brawl mode, firing just the SL, it also runs at 66% heat efficiency while doing better DPS.
    Second, it has a nearly 40 damage alpha strike. With the fast recycle of the SL, it can do 96.4 damage in < 7 seconds. This can come as a surprise to much larger chassis, a lesson often learned too late, :)
  5. Auriga
    Auriga MechSpecs Addict
    599
    Giving a try, i need to buy one more BJ for the effciency ;)
    EDIT: Made a slight variation in the rush to the dropping queu, with AMS and XL295
    EDIT 2: Its damn funny to run!!! :) :) :)
  6. Archwright
    Archwright Benefactor
    1,218
    This thread really makes me want to play some Blackjacks.
  7. epikt
    :wub: BLACKJACKS ARE FORKING AWESOME! ^_^
    (it had to be said)
  8. dranozir
    83
    I use this :
