This one use a more conventional STD300 engine. Double ERLLas for long range attack, UAC5 for short bursts of damage, and the standard close range 6x MLas + SRM4. Nothing fancy here, Simple, Sturdy. Swap between ERLLas/LLas if you want range/cool, you can also swap between AC5/UAC5. Swap to LLas, AC5 and use the tonnage to upgrade to SRM6 As usual, play with the ammo/armor until it fits your style. *BUDGET BUILD* THE GOAL IS TO MAKE A BUILD WITHOUT BUYING ANYTHING NEW, USING ONLY SCRAPS IN YOUR GARAGE. Yes, I am low on cbills, and until then I am going to use this. This mech comes with DHS, but you do need some cbills to do various upgrades. So until then I put together this. I did not use any cbills doing this. Obviously it is not as good also.
