So before the skill tree, this build was pretty fun, but now.... Man this thing is NASTY! Like 900 damage, 5 kills, 4 kmdd, 3 solo kill nasty. Goes 66 kph with a 66 point alpha (Don't do this unless you are about to die anyways.) You fire your LPLas in staggered shots of 3. This thing can left, right, left, right without overheating on temperate and cold maps for a total of 132 damage in about 4 seconds. Skill Tree: https://tarogato-mwo.github.io/mwo_skill_planner/?63a4ae5b-423b-11e7-ae4c-eb3e20da03c8 If you max out Mech Operations tree, the heat drops pretty quick. With Survival tree maxed you can put in your 132, twist to the side, soak up a lot of damage in your arm while you cool down, then do it again. With maxed Mobility tree you go 66 kph and torso twist like a heavy. This thing is a great left side peeker, a great right side peeker, and can usually take out anything that gets close as well. 4 of the 6 LPLas are very high mounted. Recommended fire groups: 1. 3 Left torso LPLas 2. 3 Right torso LPLas 3. 2 high mounted left torso LPLas 4. 2 high mounted right torso LPLas
This is now completely ruined with the LPL nerf and Banshee hardpoint nerf. The 5xLPL build MIGHT still be ok, but just think of this build as a "fossilized meme."
Just update to the new SHS meta! And of course with LLs instead of LPLs because LLs are finally a viable alternative
