Bounty Hunter "Nutcracker" (1xLBX20, 7xML, STD300)
4 ratings
Thread in 'Bounty Hunter II' started by Shock, Apr 10, 2018.
  1. Shock
    876
    357
    With solid defense, maximum mobility for the variant and enough cooling to do this on a hot map
  2. Excalibaard
    5,272
    How is that 7th laser working out for you over 6? I don't really like dipping into ghost heat.
  3. Shock
    876
    357
    I group the 7th laser with the LBX, mostly because of the similar mounts. I try not to engage over 400m so I don't have to lead the target much and the spread of the LBX lets me get most of the shells on target while still landing the laser.
  4. Tactix
    Tactix New Member
    Thinking about switching from my LFE 2SNPPc 1 AC20 build, hate to lose the LFE but I guess there's better dead side tanking?
    P.S. Do you have a skill tree for this?
  5. Shock
    876
    357
    Here's what I get from the in-game exporter
    a1f1b836d604fdcd6be0d83c3bc6260c030000000d80ed37ea59a10000000
    Tactix likes this.
  6. Tactix
    Tactix New Member
    Sorry for the late reply, I'll give that a look after work, thanks! It's a great build btw, been using it since my first post on this thread
  7. ShooterMcGavin80
    519
    I also went with an LB20 on my Bounty Hunter. I swapped out an ERSL for 1 medium laser to avoid ghost heat. Put the ERSL in the lowest mount in the left arm.
  8. Gun Tuv
    Gun Tuv Well-Known Member
    169
    Well, this is a pleasing machine! I've swapped the head med to an ERmed so the range better matches the LB20X (they are grouped together, as per Shock's advice). I love a mech that feels deadly on 0xp; you know it'll only get better - and getting it elited will be a pleasure rather than a grind.
  9. DogSoldieR
    DogSoldieR Active Member
    I switched out the 7 ML with 7 SPL with the LB20X boomstick.
    Pin point alpha on anyone will kill them. If they do not die on the first hit, try again.
    They WILL go down, see below testimony from a brawl I played
    I did not manage to do too much damage as they do not live long enough for me.
  10. DogSoldieR
    See my post. Made a mistake forgot to rate
