Nobody ever posted this build? Wut? Classic scout 4xSRM6+A with best cooling efficiency, good speed, enhanced survivability (LE and armor on arms) and good spread (artemis is still very useful despite the nerf). This build is not the absolute best when facing target with 270+ range weapons, but it can still be very useful and can be used efficiently in most situations. If you are using a 6xSRM4 boat and happen to overheat at every game, trust me: you will prefer this build because if you won't be focused from the start, you will still have to rely on coolshots int the "end game" but not as much as the 6 launcher build (you gain a -2 HPS overall, without counting the DHS). Best used when in hot maps due to the good heat efficiency of the SRM6 and the additional DHS... Since this build has a light engine and you even have armor to spare on you arms, you can shield with one side and purposely lose a side once it is cored instead of shielding with the other side torso. Due to the fact you have artemis and you can't DPS race against most clan builds, do NOT hug your target, instead try to always keep some distance, preferably ~100 meters.
