CDA-3M "Damn it works !" (1xRAC5, 4xML, ECM, XL265)
4/5,
Discussion in 'CDA-3M' started by SuperPignouf, Jul 24, 2017.
  1. SuperPignouf
    SuperPignouf Junior Member
    Yay, 800 damage on first game (a losing one). Works surprisingly well.
    dog_funtom likes this.
  2. dog_funtom
    dog_funtom Well-Known Member
    Indeed, it does work! Played 4 matches — all lost, but all resulted in "=". 5th matched resulted in ↓, but it was a special case of hopeless. (The hell, PGI? Give me normal match, so I can test this build more properly, dang it!)
  3. Ragnahawk
    Ragnahawk Well-Known Member
    186
    31
    Mediocre. There's some damage here, but it takes too long to be effective. Way too much effort put into accuracy to make it deadly. Why not just run a UAC10?
  4. Hakaan
    Hakaan New Member
    if you are not totally dumb you can see that RAC is 10T and UAC 13T, UAC 4 sustained DPS, RAC 11 sustained DPS, so by reflecting a little bit you can easily understand that RAC is much more effective
    A little variante optimised for close range, with all range skill tree ERSml : 260m optimal range, so you can hit at 300m, that is more than enough,
    you can put a bigger engine by removing the shield on the arms
    2nd variante with less alpha power but better sustained dps and better range
    two differents styles but two effectives
  5. Ragnahawk
    186
    31
    Jujushinobi said it was horrible. I haven't played it myself that much (Tried PTS). Is it as good as you say it is?
