I had a 275XL leftover from mastering my Wolverine so I thought I would come up with a different take on my classic Lancer. Here is what I came up with.... It still has the AC2 for the harass but is much more accurate close in and with the BAP and Streaks, much more capable with dealing with pesky ECM lights. Also the LPL gives it more zombie reach when your arms are gone. Advanced zoom and sensors would do well here as well as UAV and cool shot if needed.
You need to use complete links, not youtu.be, without "s" after http and without any complement in the url (playlist or whatever). Code: http://www.youtube.com/watch?v=vKosBZ_FXCY gives you
Buisness, there is a reasonable fee for your request. And an ERLL would compromise the build. I have tried but too many things need to be moved and you have to give up FF or endo to accomplish it. Since the ERLL makes more heat it would follow the tons saved would go to DHS, but the slots just arent there for them. Believe me, I have been tweaking this for a while. The only real variant to this is remove the BAP and Streaks and replace with 3xSRM4 with 2 tons ammo. Again, heat is an issue with this variant. Perhaps chainfire...?
Chainfire only helps management when almost overheating, it does not reduce the heat on a mech like yours that suffers no penalty.
