1. Welcome to MechSpecs!
    --Cheers, the MechSpecs Team.
CRB-27 "Wubcrab" (5xMPL, STD300)
4/5,
1 rating
Discussion in 'CRB-27' started by Skillblack, Oct 6, 2015.
  1. Skillblack
    Skillblack New Member
    So Yeah, to me it seemed like this could be quite a bit of fun.
  2. CaptRosha
    CaptRosha New Member
    Oh, I like the Wub!
    You inspired me ... a few slight tweaks and I came up with
  3. Skillblack
    Very cool idea as well, I decided on the STD, in the hopes of stalker sydrome on this thing, tho. Both of these will work very well I think.
  4. Excalibaard
    Excalibaard ComStar - First Circuit Staff Member
    3,168
    507
    219
    Might as well drop to a STD285 if the slots go unused. Gives some more cooling.
    I think it's a bit of a waste of the Dual AMS though, so I'd probably run this instead (partially because I have an unused STD275):
  5. Trippton
    Trippton Active Member
    I was asked to merge my builds into similar threads, so just doing as asked :)
    Here is my take on the wubcrab. With the December quirk pass, this crab variant now only gets a +10% Energy Range (No more AMS bonuses).
    Medium Pulses give a little more bang for your buck and keeps mostly the same setup as a ML version minus some DHS and AMS Ammo. Slightly more damage while still getting +10% to laser range and 2k rounds of AMS protection. Max armor and an XL for getting around and keeping up with your team. This is what I've been running with as my primary loadout.
  6. Sandwhichishere
    Sandwhichishere New Member
    This is what I'll likely run when I get the spare C-Bills to buy and equip one. It has BAP because I feel BAP is rather useful when taking on ECM Mechs in close range or finding ECM Lights as the short beam duration is excellent for light hunting though my build may be a bit slow for it. AMS to protect against LRM's while you close the distance.
  7. CarloArmato
    CarloArmato Advanced Member
    476
    99
    Good close range crab: enough DPS to not fear a brawl, but not enough tanky or fast if you need to charge your enemy up front.
    Personally, since this mech must be used as a support mech (mostly help your bigger brothers to kill someone, support your team's push or fend off close light) I would like to clarify two of my thoughts.
    First, despite others builds, I would use a Standard engine because this crab has most of its weapons on torso and your head: you can zombie around with both torsoes destroyed. Since I have this opportunity, I would not use an XL engine.
    Second, IMHO this mech doesn't actually have enough alfa to go solo or look for trouble all alone, despite having decent tank. For this reason I would also place double AMS to help you and your comrades against incoming LRM: with "AMS overload" you can annihilate most of the incoming missiles, unless you have to deal with multiple heavy-assault LRM boats. I'm using only 1 ton of ammo because this mech is ment to help out a push or cover your slow bros before they take cover, not to destroy LRM during the entire round (and TBH only once I nearly emptied this 2000 AMS ammo supply).
    This is my actual loadout
    If you don't like AMS, you can just replace them with an additional DHS and replace some armor
  8. skribs
    skribs Legendary Member
    1,622
    142
    I don't remember which specific engine I have, but I wanted a tanky Mech, and the Crab 27 with STD engine, 2 AMS, and 5x MPL was suggested.
    I don't even bother torso twisting. It just happens on it's own (Stalker Syndrome) and the result is glorious. I've had several matches where I end with less than 25% of my health and still have 4 MPLs.
  9. rinco
    rinco Active Member
    57
    Now we can build the Crab with a LE. Slightly slower but with better cooling efficiency and survivability. I am using the CRB-20 because I had planned to build the XL version posted elsewhere. But then Civil War happened and I think LE makes for a better Crab.
    You could go endo+ferro, increase the engine size and lose some heat sinks. Then you would get a slightly faster hotter Crab.
  10. Shock
    Shock Benefactor
    444
    151
    53
    Swapping out FF for Endo in your first build lets you upgrade to max armor and 300LE while only dropping 1 DHS
    rinco likes this.
  11. CarloArmato
    476
    99
    TBH I wouldn't use ANY Light Engine on this crab: you would lose one of the highlights of this crab, which is go into zombie mode and soak up the damage by shielding with your destroyed side torso/torsoes. It does have the hardpoints and hitboxes to do so.
    This little thing can still dish out some damage with both torsoes destroyed (it will still have 3 MPL out of 5!) and can be extremely though to kill if played correctly by torso twisting and shielding with the right timing.
  12. Excalibaard
    3,168
    507
    219
    Yes, Standard engines are amazing on the Crabs!
