My favorite Build on the 1C. High Firepower with decent Cooling. If some Fools get in front of you, just unload everything and then quickly sneak away. Continue this Hit&Run Tactic and you'll do fantastic scores. Alternate "Super-Ammo" Version by downgrading the SRM Launcher: Alternative with Standard Engine: testrun: [img width=700 height=437]http://i41.tinypic.com/90dg5l.jpg[/img] Blagg
I really like your first build. Good speed, and good weapons. I'll have to test it to like it, but 4-5 for a good concept.
I like it. Plenty of DHS to keep those MLas firing and that SRM6+AC10 give a nice alpha. How do you set up your weapon groups? Do you put all 4 MLas in one or do you use 4 weapon groups with 2x2MLas? When i run this dragon i try to use 4 groups and fire the fourth with the "4" key. Those usually are SRM's. 1-3 are the 3 mouse buttons.
I put all MLas in Groupfire (it's cool enough) on "normal" maps. My Weapongroups: 1. AC10 (A bit Sniping) 2. MLas (combined) 3. SRM6 (close range) 4. MLas (chainfire @ high heatlevel) 5. Alphastrike (Finisher) If you don't have a 5-Button Mouse, you can use the first three Weapongroups. Usually you don't overheat fast, if you don't fire the AC10 + MLas at the same moment all time.
Ah, i see. I just use a three button mouse. Don't you find it annoying when two of the four lasers go off target?
debating on trying this but dropping the AMS and SRM for SPEED. It's only 10kph more though, so it may not be worth it and AMS+SRM (if it registers) may be a better move like the Original Build.
I think it is a GREAT idea! I would go further than 340 even. Wit just 4 med lasers and an AC10 you can skip a heatsink imo. With an even bigger engine, less HS, all the HS in the engine, you can add FF. This (with same leg shaving) will give you another 2 tons! What do you think of this: It also has one more ton of ammo.
I sometimes run this. I think it's inbetween the Original Idea and the cry for more speed approach of yours.
