DWF-B "Five by Five" (5x cUAC5, 5x cERML)
1 rating
Thread in 'Dire Wolf Omni Builds' started by 00ohDstruct, Jun 22, 2014.
  1. 00ohDstruct
    00ohDstruct New Member
    5x CUAC5's
    5x CERML
    The heat is manageable for the DHS's with the CUAC's group fired along with either timed group fire lasers or chained.
    720 ammunition is enough to do quite a bit of damage, and the backup lasers fill in when the CUAC's are spent.
    One could also shave off a few points of armor in the legs to add an extra 1/2 ton of ammo for the CUAC's too.
    Sincere apologies, Michael. I wasn't feeling good earlier when I began.
  2. The Verge
    here you go, one B variant 5x5. BC I
  3. Michael
    Good nuff for me.
  4. Thiak
    Thiak Well-Known Member
    244
    i did the same build with ac/5's
    running the weapongorups like this:
    1. RA/RT ac/5
    2. LT ac/5
    3. MLas
    if you put the ac/5's on chainfire you still pretty much shake your enemy cockpit nonstop and you dont produce quite as much heat.
    you lose pretty much no overall(or sustained) dps but imho its a gain if you have no jamming weapons.
    i also removed some leg armor to add another DHS
  5. 00ohDstruct
    Well the idea of haivng UAC's on this Dire Wolf is not for a sustained fight, but for melting the face off of a mech during a push, or sending a lot of suppressing fire against a group in a short amount of time. The heat build up from the 5 UAC's is not so severe that it isn't manageable with a doubletap or three. The 5 ER mediums are there to either chain fire or to use as backup if a few UAC's jam up.
    Using normal AC's, however, would be advisable for less experienced pilots who can't control their bursts well or gauge when to attempt a double fire.
  6. Solahma
    5 cUAC5 + 6 cERML
    My variation after playing with Korea for several drops and watching him average 1000 damage per game with something similar. (actually went above 1000 damage at least 3 games in a row o_O)
    Here are the major decisions for my variation:
    1) The Center Torso "Prime" omnipod has movement quirks where the "B" omnipod does not.
    2) The Right Arm "A" omnipod gives the build the option for Lower Arm Actuators which are particularly useful to get extra maneuverability out of those arm-mounted cERML. Keep your arm lock key nearby so you can lock/unlock on the fly when needed. Lower Arm Actuators are very handy when you are trying to do surgery on a certain mech component.
    I initially ran this build with 7 tons of ammo and I have consistently ran out of ammo near the end of every match. I would advise at least 7 tons, but 8 tons seems to be the perfect amount to keep those cUAC5s firing for as long as possible. If the build is too hot for your liking, you can always trade 1 ton of ammo for another cDHS, but it won't help as much.
    This build has averaged ~900 damage for me over 6 games so far. It's the most consistent build I have run in a Dire Wolf to date. It melts face very well :D
  7. Cord78
    Cord78 New Member
    My take on this build.
    little more ammo, UAc 5's and a TC1
  8. Solahma
    Just a taste of this build's potential. Watch how quick these mechs fall to its fury.
    A proper video to come.
    http://www.youtube.com/watch?v=_ZDTURvLU9A&feature=youtu.be
  9. Thiak
    244
    it is insane, i know, but i rather go with 1 more heatsink and 1 less ML
    not to forget with the A right and Prime left arm you increase your energy cooldown by an additional 7.5%, so all in all i think 5 by 5 is better
    cord78, dont put ammo in your ct, never ever (if there is space somewhere else)
    the clanmechs might have everything cased by default, but NOT the CT
  10. Solahma
    I'll give it a try next time I jump into the game. The increased cooldown time doesn't effect the 5x6 much considering you need to wait and dissipate heat anyway. You will never notice the increased cooldown time because of that tbh.
    I can see the advantages of the original build though, definitely. I'll be sure to post my impressions.
  11. Rhent
    Rhent Junior Member
    Swap the right arm for a prime omnipod and you can spread out your ML between both arms and not worry about losing so much of your armament if you get torsod on the left.
  12. Solahma
    you could do that. It would mean increased energy weapon cooldown time though. If you'd rather go down that route, I would highly recommend a Prime left arm and an "A" right arm to get the lower arm actuators. The added flexibility has helped me a lot, instead of always relying on the whale's horrendous torso twist angles.
  13. Matta
    Matta New Member
    This build should be banned by law and constitution and ever mention of it should be sanctioned by death penalty ! :D
    This build is pure awesomeness, face melter, law giver, pain bringer, grave digger, Chuck Norris of Mechs builds ! :phear:
    Played properly, it will dish out so much damage it can turn the course of battle in a matter of seconds.
  14. irbr
    irbr New Member
  15. enileph
    Maybe more ammo. 2 tons per gun is minimal.
    Was running with less UAC and more ERML, the Config A version RA allows for better arm movement.
  16. CaveHermit
    CaveHermit New Member
    I build this variant for fire suppression.. Put the Ballistics on weapon group one chain fire.. Put the Energy on group two and chain.. And and your near heat neutral on most maps. This thing just throws the lead around.
  17. Kiltedbear
    Kiltedbear New Member
    Did this change? because my ct's say "C.A.S.E protected"
  18. Solahma
    C.A.S.E. doesn't protect your engine. Ammunition explosions will still damage the component they are stored in. Useful everywhere except for your CT and your Head.
  19. m0nkeyduke
    m0nkeyduke New Member
    I run my Prime w/ 5xCUAC5 + 4xcSPL + shitloads of ammo and it´s ridiculous. I don´t consider myself a good pilot but this build brings EVERYONE into the 1000+DMG club.
