So that stock take BEFORE I buy modules..... 360 Target Retention 2 AC 10 Cooldown 1 AC 10 Range 1 AC 2 Range 1 AC 20 Cooldown 1 AC 5 Cooldown 1 AC 5 Range 1 Adv Seismic 3 Adv Sensor 9 Adv Target Decay 2 Adv Zoom 1 AMS Overload 4 Capture Accelerator 2 c ER PPC Cooldown 1 c ER PPC Range 1 c ER LL Cooldown 1 c ER LL Range 1 c ER ML Cooldown 1 c ER SL Cooldown 1 c ER SL Range 1 c GR Cooldown 1 c LB 20X Cooldown 1 c LRM 15 Cooldown 1 c MG Range 1 c MP Cooldown 1 c MP Range 1 c S-SRM 6 Cooldown 1 c S-SRM 6 Range 1 c SRM 4 Cooldown 1 c SRM 6 Cooldown 1 c SRM 6 Range 1 c UAC 10 Cooldown 1 c UAC 10 Range 1 c UAC 20 Range 1 c UAC 5 Cooldown 1 c UAC 5 Range 1 Enhanced Narc 3 ER LL Cooldown 1 ER LL Range 1 ER PPC Cooldown 2 ER PPC Range 2 GR Cooldown 1 Improved Gyro 4 LL Cooldown 1 LL Range 1 LPL Cooldown 2 LPL Range 2 LB-10X Cooldown 1 MG Range 1 ML Cooldown 2 ML Range 4 MPL Cooldown 1 MPL Range 1 PPC Cooldown 1 Radar Deprivation 8 Shock Absorbance 2 SL Cooldown 1 SL Range 1 Speed Retention 3 SPL Cooldown 1 SPL Range 1 SRM 4 Cooldown 1 SRM 4 Range 1 SRM 6 Cooldown 1 SRM 6 Range 1 S-SRM 2 Range 1 Target Info Gathering 6 UAC/5 Cooldown 1 UAC/5 Range 1
I outfitted a range and a cooldown module of each of the main types of weapons that I use (non missile weapons) just to have laying around as spare. Thank you all for your hard work, I enjoyed my weekend doing anything but MWO
I just focused on the modules that fit my usual playstyle...I picked up the PPC/ERPPC and Gauss modules finally, and filled in some gaps with lasers (was missing cSPL modules, which I now use on several mechs), and ignored a lot of the rest. I tend not to use cUAC/ACs often, but I did grab some LBX cooldown modules as well. At this point, I just need one more module, and I'm back to saving up cbills for next week...I just purchased what I knew I liked on builds, which won't change because of quirks.
I'm trying to ignore that my list of modules I'm after is 23 long..... Mmmh and the MWO stats tell me I only have 29,310,961 versus the 37,950,000 I need. Can I be arsed to grind tonight and tomorrow night after my horrendous 7 losses in 9 matches last night.... That is the question....
Got cSRM6 cooldown module too (love this build https://www.mechspecs.com/threads/scr-p-infradead-5x-cersl-3x-csrm6-a.7571/ and since SCR has only 3 slots it's SRM6 CD+ seismic and radar). This sale is too long, I will end up buying all modules
Just caught a glaring omission so a simple question and I'll churn c-bills to get these on top as I can.... What order would you prioritise buying IS LRM modules?
5's that useful? I've only ever used 15's and 10's before... ok I admit it .... dual lrm 20 ONCE back a couple of years ago when I didn't know better! Shamefully might have been a AS7-D as I couldn't do anything with that mech...
I put 5s on the highest priority because I think the Golden Boy is one of the best LRM spammers out there.
Because I'm sad (and have too much leave banked) I took a day off and madly ground c-bills. Picked all the LRM modules up for the IS and Clan. Of course I also found some missing modules as I'd forgotten the inventory doesn't include the (G) (I) (P) etc mechs.... duh.
Well that's painful my wallet now holds a grand total of 24,692 C-Bills... and I have 6 resistance mechs to fit in 5 days.... End result though: 360 Target Retention 2 AC 10 Cooldown 1 AC 10 Range 1 AC 2 Range 1 AC 20 Cooldown 1 AC 20 Range 1 AC 5 Cooldown 2 AC 5 Range 2 Adv Seismic 3 Adv Sensor 10 Adv Target Decay 2 Adv Zoom 1 AMS Overload 4 AMS Range 1 Capture Accelerator 2 c AMS Range 0 c ER PPC Cooldown 1 c ER PPC Range 1 c ER LL Cooldown 1 c ER LL Range 1 c ER ML Cooldown 1 c ER ML Range 2 c ER SL Cooldown 1 c ER SL Range 1 c GR Cooldown 1 c GR Range 1 c LB 20X Cooldown 1 c LB 20X Range 0 c LB 10X Cooldown 1 c LB 10X Range 0 c LB 5X Cooldown 1 c LB 5X Range 0 c LB 2X Cooldown 1 c LB 2X Range 0 c LPL Cooldown 2 c LPL Range 2 c LRM 20 Cooldown 1 c LRM 20 Range 1 c LRM 15 Cooldown 1 c LRM 15 Range 1 c LRM 10 Cooldown 1 c LRM 10 Range 1 c LRM 5 Cooldown 1 c LRM 5 Range 1 c MG Range 1 c MPL Cooldown 1 c MPL Range 1 c SPL Cooldown 1 c SPL Range 1 c S-SRM 4 Cooldown 1 c S-SRM 4 Range 1 c S-SRM 6 Cooldown 1 c S-SRM 6 Range 1 c SRM 4 Cooldown 1 c SRM 4 Range 1 c SRM 6 Cooldown 1 c SRM 6 Range 1 c UAC 10 Cooldown 1 c UAC 10 Range 1 c UAC 20 Cooldown 1 c UAC 20 Range 1 c UAC 5 Cooldown 1 c UAC 5 Range 1 c UAC 2 Range 0 Enhanced Narc 3 ER LL Cooldown 1 ER LL Range 1 ER PPC Cooldown 3 ER PPC Range 3 GR Cooldown 1 GR Range 1 Improved Gyro 4 LL Cooldown 2 LL Range 2 LPL Cooldown 3 LPL Range 3 LB-10X Cooldown 1 LB-10X Range 0 LRM 20 Cooldown 1 LRM 20 Range 1 LRM 15 Cooldown 1 LRM 15 Range 1 LRM 10 Cooldown 1 LRM 10 Range 1 LRM 5 Cooldown 1 LRM 5 Range 1 MG Range 1 ML Cooldown 2 ML Range 5 MPL Cooldown 1 MPL Range 1 PPC Cooldown 1 PPC Range 1 Radar Deprivation 8 Shock Absorbance 3 SL Cooldown 1 SL Range 1 Speed Retention 3 SPL Cooldown 1 SPL Range 1 SRM 2 Cooldown 1 SRM 2 Range 1 SRM 4 Cooldown 1 SRM 4 Range 1 SRM 6 Cooldown 1 SRM 6 Range 1 S-SRM 2 Cooldown 1 S-SRM 2 Range 1 Target Info Gathering 6 UAC/5 Cooldown 1 UAC/5 Range 1 Yes there are 7 modules I couldn't be bothered to buy even at 45% off...... Edit: plus the flamers.....
Yepp,.. Might be worth if you have the STK-3H in your garage. Otherwise the smaller Launchers are better weight/slot/sDPS-wise
Saving grace is I spread my purchases all over so at least I'm not totally screwed by the changes. And no... @Durandal I refused the dubious lure of flamers.
Did the same got range and cooldown of the weapons I like, cooldown only sometimes, with the quirk system mechs will always cycle. Now with the quirks preview I can check if I need something else. Looking especially if there will be a decent IS PPC mech.
Yeah but my triple set of ER PPC Cooldown/Range and double set of LPL Cooldown/Range modules are feeling unhappy. If only the AWS-9M had better hitboxes I'd be tempted by AWS-9M x 2 and FS9-A x 2 or Oxide x 2 ..... or Panthers!!!!!!!
I tried 2x ERPPPC + 3x MLS + 2x AMS on the 9s before and it worked pretty well, so this one will probably stay in my dropdeck. Jester might be a nice candidate for this role as well, though...
