1. Hi everyone!
  2. Welcome to MechSpecs!
    --Cheers, the MechSpecs Team.
FS9-A "FS9-H Replacement" (6x ML, 2x SPL, XL295, 1x JJ, 3DHS)
Discussion in 'FS9-A' started by Epydemic2020, Jun 18, 2015.
  1. Epydemic2020
    Epydemic2020 Well-Known Member
    102
    The FS9-H can run 6ML with 14 DHS and gets a 5% range buff and a 10% heat reduction.
    The FS9-A can run 6 ML and 2 SPL with 13 DHS and gets a 5% range buff and 7.5% heat reduction.
    It is essentially the same mech, except the A can deliver enough of an alpha strike to headshot an overheated mech in one blast.
