    -- the MechSpecs team.
  2. Welcome to MechSpecs!
    --Cheers, the MechSpecs Team.
FS9-A "Super heat boy" (8x Flamers, 1x JJ, XL295)
Discussion in 'FS9-A' started by dranozir, Feb 6, 2014.
  1. dranozir
    For burn in hell !
  2. Solahma
    Solahma Space Pimp
    FYI this would overheat YOU in ~10 seconds :rofl:
  3. Boeruine
    Boeruine New Member
    Not necessarily. The key to flamers is cycling them. 4 weapons groups of 2 flamers on cycle could go for a pretty long time without overheating.
    Give it a try with a Jenner 7F, and equip 6 flamers and go into training grounds. I chose Forest Colony and the Cicada as my test subject. Using the above stated setup it takes 20 seconds to kill the Cicada, and only builds up +/- 10 heat. Using all six in a single weapons group as an "Alpha" strike kills the same Cicada in 11 seconds and brings you up to 90 heat in the process.
