1. Welcome to MechSpecs!
    --Cheers, the MechSpecs Team.
GAR-D "Dragon 1V" (1x cLBX20, 4x cERML)
4.66667/5,
6 ratings
Discussion in 'Gargoyle Omni Builds' started by The Verge, Dec 9, 2014.
  1. The Verge
    4,305
    464
    221
    If you like Dragon's, you might just like this. But with only 4 tons of ammo, your going to have to use speed to your advantage.
  2. LT Satisfactory
    LT Satisfactory Benefactor
    815
    61
    In about 6 matches, I haven't lost an arm yet, so I'd rather do this build using the A arm to put all the erml's together. I also cut some armor/.5t ammo just because I always feel the need to take a tc1.
    Def shaping up to be the 3rd place variant, but each one can't be a pure laser boat.
  3. Remarius
    Remarius Space Pimp
    Levelled up with LT's arm based version of this build and found it very solid even doing basics - using the ERML range/cooldown due to the ammo amounts. Will add the cooldown LB20X once mastered.
  4. Durandal
    Durandal Legendary Member
    2,150
    680
    Great 1-2 punch with the ERMLs followed up by the shotgun, had a lot of success, including a 4k game before it even had all basics:
  5. Durandal
    2,150
    680
    Getting mine through the elite states, with only full regular basics it is already getting nasty:
    This thing is a core ruiner if you roll in with 2-3 teammates. At the end, I had a 6 MPL firestarter picking at me, and still managed to down 2 TBRs and a LCT, then the Firestarter died, and their last guy/TBR managed to finally get my CT down. Ignore this build at your peril, for it almost makes me like the Gargoyle ;) (Video inc soon)
  6. Durandal
    2,150
    680
    Roll out! This is the best video I could get to show the power of this build. I die in the end, but I bring half a team with me.
    MeglaManiac and The Verge like this.
  7. Renegademaster
    Renegademaster Well-Known Member
    106
    Undoubtedly the best Garygoyle build, however i prefer an Ultra AC-20 to the LBX-20.
  8. Trifler
    Trifler Active Member
    53
    What about using two cMPLs and both GAR-Prime arms to double the LB-X quirks?
    or using an SRM to maintain the firepower rating?
  9. Durandal
    2,150
    680
    Your link's broken (not sure what that is, that string doesn't look like a smurphy string), but losing 12 firepower by going to MPLs only is too big of a trade for this build. The LBX20 is powerful, but its greatest ability is its crit potential on exposed components...by losing 2 ERMLs, you make it take that much longer to get past the armor, which means the LBX is not going to be as nasty as it could. The extra 10% cooldown means it could fire more, but you're still going to want the lasers to get the armor off that mech faster.
  10. Trifler
    53
    Ok, good points. The firepower rating appears to only take alpha damage into account, but I think you're still right.
    Other than that, one can pick the GAR-D CT for faster acceleration/deceleration or the GAR-A for slightly better turning.
  11. enileph
    enileph Space Pimp
    Use ERSL for higher damage up close. You like it up close, right?
  12. dog_funtom
    dog_funtom Well-Known Member
    Great brawler and finisher.
  13. Durandal
    2,150
    680
    Yeah, this mech still GOES man. Pulled it out in a Stream, and never did under 400 damage with 2-4 kills XD
  14. dranozir
    83
