1. Welcome to MechSpecs!
    --Cheers, the MechSpecs Team.
Invasion GHR-5P "Hoppa popper style" (2xLPL, 3xERML, 3xML, 1xJJ, LE325)
Discussion in 'GHR-5P' started by CarloArmato, Oct 2, 2017.
  1. CarloArmato
    CarloArmato Advanced Member
    I was about to name it "smart hopper".
    Best used with a mouse with side buttons: you should group the weapons based on the weapon type.
    1. 2xLPL
    2. 3xERML
    3. 3xML
    LPLs and ERMLs have the highest reach and are high mounted (so use then when they are the furthest away), while every non-ER ML is low mounted and will probably be used only for brawls or for CQB (thanks to this 'mech quirks, they will have a minimum of 297 optimal range). With an alfa strike, you should reach no more than 50% with good skills. At close range, use ML and LPL (or go for an alfa if you are cool)
