Reverse engineering of an hubchback found in invasion. Maybe not optimal for invasion, but can deal a decent punch / DPS even up close. The idea behind this build is that if the target is above 100-150 meters, you have enough range to pinpoint a component with your ERPPCs, otherwise you can still deal damage to whatever component you like with short duration, decent hitters, low heat lasers, with little to no risk to overheat. If the enemy has a flamer, you should be able to perma-chain fire those cuPL.
