Theory-Crafted (I don't even own a single Battlemaster ) Now obviously, this weapon-loadout could be loaded just as easily on a Stalker --- and in fact, so far as hard-point placement goes, it would actually be BETTER on a Stalker than on a Battlemaster (higher mounted weapons, especially in the arms). But in any case, the one advantage this Battlemaster has over the Stalker is its amazing speed capacity, which is what this build is designed around. What you get then, is an SRM-Brawler Assault with some amazing speed, good backup weapons for both long- and close-range engagements, and a decent heat-efficiency. Don't forget to check out the MK-1 Version of the build: Comparison --- PPCs instead of LLasers, and mounted in the Torso instead of the Arms, for higher placement, though you lose the horizontal movement of the lower-arm-actuators; 5 kph faster, though at the loss of 4 DHS and a slight bit of armor; ES makes it slightly more expensive, as does the larger XL-Engine. On paper, at least, I prefer MK-2.
