CTF-IL-T2 - 76.4 kph (300XL) This is another upgrade to the stock Illya. It's very similar to Blagg's Terminator CTF-IL Terminator but it trades a medium laser for more speed (71.3 kph-->76.4 kph). Main reason for "Upgrade" [list type=decimal] [*]I found that the arm ML was more of a distraction & heat build up. [*]In a brawl vs mediums and lights the arm ML didn't converge well with the torso MLs. [*]I also use the AC5s a lot in those fast brawls and need to lead those a bit. So more often than not the arm ML is not tracking the target for it's full duration. [*]The extra 5 kph may not seem like much, but in a heavy it really helps when you find yourself out numbered and need to bug out. It may also help with torso twist speed, but I haven't been able to quantify a difference. [/list]
5/5, I think that's pretty much the best way to go with Ilya Definetly 5 star, even tough the ammo placement is not the most optimal, but i guess it's a personal choice.
