1. Hi everyone!
  2. Welcome to MechSpecs!
    --Cheers, the MechSpecs Team.
JM6-A ''Boomquirk" (2xAC/20, 2xML, XL280) 'Best boomjager chassis'
Discussion in 'JM6-A' started by Hellhoundlover, Apr 20, 2017.
  1. Hellhoundlover
    Hellhoundlover New Member
    To me this is the perfect boomjager chassis. The reason is quite simple, it's balistics quirks.
    With the mechs innate quirks and a AC/20 range module you'll have a 30% range and 35% ballistic velocity boost on your AC that make mechs go pop. Your other weapon module(s) is really up to you. Radar deprivation and seismic sensor i would definitely recommend for hit and run tactics and brawling.
