1. Welcome to MechSpecs!
    --Cheers, the MechSpecs Team.
JM6-A "Patch Protagonist" (2x AC10, 4x SRM2, XL255)
4/5,
1 rating
Discussion in 'JM6-A' started by Excalibaard, Apr 24, 2014.
  1. Excalibaard
    Excalibaard ComStar - First Circuit Staff Member
    3,168
    507
    219
    So in the last patch AC10s became one of the most useful ACs, and SRM2s got a huge cooldown buff.
    Chainfiring 4 SRM2s is perfectly aligned with these new cooldowns so they can be used as a close range harass and are a more powerful than the machineguns from the JM6-DD build with 2x AC10 (though less DPS/tonnage). Hit registration problems with SRMs are fixed on april 28th and only occur when there are a lot of explosions to calculate, thus is mitigated somewhat by having tiny launchers.
    You can swap a ton of SRM ammo for AC10 ammo, if you find yourself hanging back more (90 shots is definitely a nice upgrade over 75)
    Also you can swap AC10s for LBX10+ML each. I advise against swapping the DHS as AC10s+ML and then mixing in SRM2s will get very hot.
    Not a gamebreakingly different build from the streaker builds for this chassis, but no lockon required and ability to fire on a certain component is nice if you have the aim for it.
  2. dranozir
    83
    Good build :
  3. SkiDog
    SkiDog Moderator Staff Member
    631
    188
    46
    Not as effective I think because of the damage spread, but the LBX version crit seeking machine
    It's definitely a different monster, but I leveled this mech with this loadout... More of a cleanup mech than anything, but effective in that aspect nonetheless.
  4. skribs
    skribs Legendary Member
    1,622
    142
    I'll have to post my exact version when I get home, but I used the extra tons from dropping down to LBX to add 2x ML.
