This is really a crap crab build. It's really between the "I want to try out this just 4 fun" and "I still want meta one way or another". This build is only possible if you are able to manage 4 different firing groups and if you like being one of the infamous batman's nemesis, because this is probably not a good build. The right side is your poking long range side: it is the Long range meta without ghost heat and unluckily no range quirks. It is nearly identical to similar IS heavies builds, like the Peekphract, and it should be played accordingly: peek from the right and keep the left side protected, or protect the right side with your left once finished firing your alfa strike. The left side is your brawling build: it's basically a light-medium sized mech. Consider it as a "decent" sidearm, so don't look for a brawl. Gauss Rifle can be used both at long and short range, while ERLLs are simply too hot to be worth using at close range.
