1. Welcome to MechSpecs!
    --Cheers, the MechSpecs Team.
KDK-3 "Stone Kodiak" (4xcGauss, 2xcERML, cSTD300)
4.75/5,
4 ratings
Discussion in 'KDK-3' started by Remover of Obstacles, May 18, 2016.
  1. Remover of Obstacles
    Remover of Obstacles Benefactor
    556
    Silly sniper fun.
  2. Spheroid
    Spheroid Well-Known Member
    200
    If you delete the flamer and one ton of ammo you can install ferro which saves you four tons. That would allow a 300 STD.
  3. Remover of Obstacles
    556
    Updated thread for 300 standard engine variant. A bit light on ammo for my accuracy, but it can keep pace with the Dire Whales.
  4. Cpt Chattahah
    Cpt Chattahah Legendary Member
    2,277
    301
    Might be a little low on ammo, but at this speed, I don't know that I'll get off 100 rounds... I'll test it tonight as follows;
    Add in a little light defense and some additional mid-range damage.
  5. Malystryxvof
    Malystryxvof New Member
    The quad gauss STD 300 variant with 90 rounds of gauss works just fine for me, but i wouldn't go any lower on the engine like some of these builds are atm, will be to slow to keep up with anything.
  6. Cpt Chattahah
    2,277
    301
    It's unfair how brutal this thing is...
  7. Cpt Chattahah
    2,277
    301
    Found that if you tie all four gauss rifles together in one weapon group it will charge one pair, then if you don't fire, it automatically charges the second pair. Makes for GREAT snap shots when you're waiting for your target to peek from cover. Gives you a good enough window it's almost like back when you didn't have to charge the stupid things!
  8. Remover of Obstacles
    556
    That might be the first 4 star rating with a 1200+ screenshot that isn't a lrm-boat.
  9. Spazamataz
    Spazamataz Junior Member
    IT'S OVER 900!!
    out the gate 900+ 4 kills (KMDD/ solo of course)
    However the name makes lies of it's awsomeness
    I propose ZAYTSEV
    after Vasyli Zaytsev the greatest sniper in the worlds history to date
  10. Riscy
    Riscy Benefactor
    156
    I like how that works. Obviously a 4x Gauss alpha would be nice but in pairs it still works pretty well and for some reason makes the charge up seem quicker. A fun build!
  11. Remover of Obstacles
    556
    In before being limited to only 2x gauss per mech.
    2xERML is the better build IMO, but this is fun for more long range damage.
    Really have to pick your location well to compensate for 45 kph speed and the LL burn time gives away your location.
  12. Flokoloko
    The 90 shot STD 300 variant is some crazy shit.... but good shit... :D
  13. Aylek
    2,676
    480
    167
    Keep in mind you probably will be able to up the ammo count per ton with the upcoming skill tree. One single point there will net you +7 shots when loading 7 tons, +8 with 8 tons and so on. This is one of the builds where those skills are shining.
