1. Welcome to MechSpecs!
    --Cheers, the MechSpecs Team.
LBK-Prime "Mr. Obvious" (2xcERPPC)
4 ratings
Discussion in 'Linebacker Builds' started by PyckenZot, Nov 17, 2016.
  1. PyckenZot
  2. Aramuside
    Aramuside Advanced Member
    268
    46
    Just to complement your post - my first win in a Linebacker was with this mech:
    Needless to say a short to medium range brawling nascar map with a lot of heat.
  3. the boneshaman
    the boneshaman Active Member
    53
    only change I would make is give it a B L/T and move the PPCs in to the torsos. try the use the arms as shields the best you can. granted it makes it harder to take out UAVs. it also puts the PPCs up higher so you don't have to expose your self as much.
  4. Aylek
    2,680
    482
    167
    This takes away the 20% ERPPC velocity from the 8/8 quirk set, though.
    BTW, why don't you do a right-sided peeker? Fully actuated arm-PPC as a bonus.
  5. Aramuside
    268
    46
    I've seen a couple like that. I like the dead siding and peeping but not sure as those mounts end up at very different heights.
  6. PyckenZot
    I consider unquirked PPCs nothing less than a complete waste of tonnage. Even though I agree the highplaced cannons would be nice, similar the the HBK-IIC I opt for LPL or erLL in those cases. Because of the aforementioned reason.
    invernomuto and dog_funtom like this.
  7. Aylek
    2,680
    482
    167
    I LOVE IT!
  8. Aylek
    2,680
    482
    167
    I am still using (and loving) the right-sided build with a TC1.
    dog_funtom likes this.
  9. Shock
    Shock Benefactor
    446
    151
    53
    Best clan PPC build I've run
  10. illVibes
    illVibes New Member
    I've been playing this build for weeks! Best LBK-Prime build I've played, I've been averaging about 350-400 points a game with this.
