LCT-3S "The Plague" (4x SRM2, XL190)
Thread in 'LCT-3S' started by PyckenZot, Nov 7, 2014.
  1. PyckenZot
    As a true harbinger of death this little squishy plague runs around the battlefield culling out the weak and sickly. It eliminates the wounded, separated from the herd, it punishes those whose bloodlust have clouded their senses. It relieves those having been crippled by the fiery death from above from their misery.
    It dies with the very first mistake it makes,...
    Remarius likes this.
  2. epikt
    Unfortunately very low on ammo.
    Have you considered lowering the engine?
  3. Aylek
    Taking just 3 SRM2 and adding a single MLas while keeping the ammo count should do the trick.
    Remarius and epikt like this.
  4. Remarius
    Yeah I defaulted to that setup when levelling my Locusts and its highly effective even pre quirk. A locust w/o speed is dead and only 1 of mine ended up as sub 190xl ... and that was 180xl.
  5. Remarius
    Should have said - grats on 5 kills in a locust though. ;)
    PyckenZot and Tulip Lee like this.
  6. PyckenZot
    It is a tee bit low on ammo yet just enough if you have decent trigger control. In essence only shoot when you know you'll hit, don't waste ammo on fresh enemies and don't go light hunting. (I suck with MLs on Locusts,...)
  7. nopempele
    nopempele New Member
    I chose XL 180 for additional ammo. This mech can be really dangerous.
  8. SirBurntChicken
    SirBurntChicken Well-Known Member
    141
    With the quirks this goes through ammo like crazy. If you're very conservative and careful 2.5 tons of ammo will last the match. To do that I suggest only shooting at bigger mechs and to shoot for the torso unless the legs or arms have already lost armor to minimize misses from small and fast moving targets. If you have to take a shot from a distance or at a fast mech only fire one or two of the launchers. This is not a light hunting mech. Remember too that SRM's are slow so get as close as you can. Finally, remember the Locust is the sir Robin of mechs. Bravely run away. Unless you're the last mech and the enemy still has 12 mechs left. Than it's time to die bravely ;).
  9. Excalibaard
    5,055
    1,107
    Personally, 2,5t wasnt even enough for 3 SRM2s, let alone for 4 SRM2s. I'm giving up a little bit of burst, but SRM2s are more of a sustained fire weapon anyway. I tried the variant from the comments, but I'll generally get more damage out of an extra ton of SRM2 ammo than I'd get from 1 ML, and this allows me to turn away faster as I don't need to wait on ML duration!
    Built it like this and have been having decent success with it and I love playing it!:
  10. PyckenZot
    I don't always drive a LCT-3S,... but when I do, people notice:
    Excalibaard and Shock like this.
