MechLab: https://mwo.nav-alpha.com/mechlab?b=08a2d025_MCII-MWKLGD Spoiler: Build Code AEhD4:_1|3f|l^|l^|QR|QRp71|eB|QR|QR|QR|QR|QRq71|QR|QR|QR|h<2|QR|QRrl0|eB|eBsl0|eB|eBt;1u;1vB0w505050 This is a shockingly good Moonwalker for how simple it is. You're loaded to the brim with ammo so good luck running out (I've literally yet to run out with how much damage you can pump out). It's a pretty spicy boy, you don't wanna alpha strike too much, but that's how you get the most damage. I recommend setting up a chain-fire weapon group and then just rapidly right-click to set up the cooldown sequence, then hold down your alpha strike weapon group to chain fire at a much faster fire rate. This rapid chain-fire method gives you good DPS and doesn't build up your heat too quickly. If you want it to be a bit cooler, invest in heat gen and cool run, ESPECIALLY cool run. This thing is so busted.
