Before going on: I didn't want to change my engine because I'm poor. If you would like to buy a better engine, just skip to the ALT. Your trusty asymmetric sniper: fire at extremely long ranges (something around 810 meters without modules) to soften up your enemies and use your small laser for anything that get close under 250-300 meters. Poke with your left, shield with your right side and your are good to go. NEVER alfa with this build: always use your ERLL in two different groups. I personally use: 2xERLL (arm mounted) 2xERLL (torso mounted) 5xERSL 2xERLL + 2 ERSL (both arm mounted) If you feel those SL are useless, you can simply boat other 2-3 HS, but I don't think it's really worth it. ALT 1: if you switch to endosteel and remove 2 heatisnks, you can fit a XL370, but overall you will lose 1 HS: it should not be a big deal and you will become way faster. I think you should use this if you can afford it. ALT 2: still endosteel, sligthly bigger engine (350XL), TC7 and swapped ERSLs to SPLs. Feels kinda right, but I've never used it.
