I still need to battle test this builds (it looks very hot), but at least on paper it should work, because it combines the spreaded alfa of the MRMs with the pinpoint damage of the LPL. Use these weapons accordingly depending on the situation (alfa to soften up armor and when you are cool, MRMs for crits, LPL to finish off or pinpoint components). Since LPL are mounted on your arms, you can track lights and medium if they are not too close or fast. You can hammer non-stop with your LPL untill you are cool enough to fire the MRMs without overheating. It also takes advantage of some quirks, especially the 10% energy range, energy cooldown and missile heat generation. EDIT: there is enough ammo for 25 MRMs alfa. By replacing one ton of ammo and maximing ammo skills, they would be 24, but with the spare ton you can fit a TC1 and increase LPL range and crit chance for your MRMs...
