This is probably the highest alfa you can achieve with Heavy Gausses and without the need to skill into cooling, but you are gonna spread your SRMs. Because it's a cool brawler, you don't need to skill for coolruns and/or heat containment, so you can skip the operations tree. Skill wise, you should preferably max out range and cooldown for maximum DPS and damage application as well as ammo, both projectile and missiles. Without skills, it can apply the same damage as a standard gauss nearly 500 meters, so you can soften up you targets while you try to approach them or when moving from cover to cover. SRMs are kind of prefered over lasers because they are fire-and-forget and you don't have to hold your crosshair over your target like lasers, allowing you to face for less time and consequently shield more/better. The name and capital-cases are a pun and they are correct
