Casual Mrm90
Thread in 'TNS-5T' started by Jane Doe, Nov 17, 2020.
  1. Jane Doe
    Jane Doe New Member
    I heard you liked mrms and refuse to mount lrms so i cheesed the mount placement via rockets and gave you mrm 90 all at eyeline. You can remove the rockets from the disposable arm for more ammunition or jump jets if you'd like.
  2. CarloArmato
    A few notes:
    • IMHO Rocket Launchers are a waste, so if you really want to fit them, use only RL10 (best overall damage/slot/tonnage ratio)
    • You have a lot of free slots: you can upgrade to endo steel and gain some tonnage
    With that free tonnage, slots and by playing around with armor, you can fit a Light Engine (better survivability)
    If you really want to go full MRM with no RL, you can achieve MRM 120 and still achieve very good cooling, despite the XL engine. Just remember to never alpha strike but fire 1xMRM40 and then 3xMRM20 to avoid ghost heat.
  3. Kurbeks
    Kurbeks Junior Member
    It's MRM 100 not 110 :D
  4. Jane Doe
    Jane Doe New Member
    The entire point of this build was to shove all mrm tubes up to eye level why have you swapped the sides lol.... hold on.
    The left side of thanatos raises the second missile inserted up to eye level meaning you won't hit the ground with anything other than the rocket 10. this allows you to stay further back when firing the mrms. On the right side, the second missiles are inserted below the already low missile pod making the right side completely disfavorable to mount missiles on.
    This build is mrm 110 and is capable of being mrm 120 if you're willing to drop the ecm.
