Casual NCT-B "Splorg" (2xcERPPC 6xcSRM6) +Set +Alt
Thread in 'Nova Cat Omni Builds' started by Excalibaard, Mar 20, 2021.
  1. Excalibaard
    5,169
    This is Splorg.
    Splorg is your friend.
    Splorg has 2 high mounted ERPPCs that he likes to tickle people with from 1000+m away, just to let them know he's coming.
    But, he has the most fun when he can get as close as possible and give people a 36 missile hug. No artemis means he should get in cuddle distance for the best single target effect.
    Go forth and spread Splorg's love (for destruction).
    Skills example:
    If you focus on having as many heat containment nodes and heat gen nodes as you can reasonably get, you can alpha on cold maps without shutting down. On hot maps you'll dip right into the 95-100% range where you don't damage yourself, but will shut down. It's probably best to fire the missile arms separately when you can, and turn override shutdown on by default. You'll also want cooldown, which stacks well with the innate 10% energy cooldown quirk from running only NCT-B omnipods, and makes your ERPPCs feel a lot better. Get missile rack skills with the first build. If you need more ammo even then, run this alternative:
