Invasion NCT-PRIME "Roasted Cat" (4xERPPC)
4/5,
Thread in 'Nova Cat Omni Builds' started by MEKA Hana Song, Oct 19, 2017.
  1. MEKA Hana Song
    MEKA Hana Song New Member
    Perhaps the most obvious and boring of the bunch. I initially tried poptarting with the NCT-A's side torso JJs but blowing at the ground really hard would probably be a more viable way of doing so.
    This thing runs hot so don't get overzealous. You'll want to rely on your high-mounted PPCs since in a lot of cases using your arms will just turn your friendly neighbourhood Atlas' rear torso to mush.
    EDIT: I decided making an entirely new thread wouldn't be worth it because it would be too similar, so just keep in mind that you can replace the PPCs with LPLs if you're so inclined.
  2. dranozir
  3. dranozir
    A good build Meka. Sorry for double post.
    MEKA Hana Song likes this.
  4. Regina Redshift
    1,293
    I'd put both the arm PPCs in one arm. For some reason locked arms on an NCT drives me up the wall.
    Edit: I should give this build a try. I'm running a laser + LBX build right now, but it's not performing super great (at least not in QP).
  5. ShooterMcGavin80
    519
    I would stick with just the arms and the set of 8 omnipods. You get a pretty healthy velocity quirk if you keep all 8. If you accept the low arm mounts you can work with them, just like the WHK-PRIME.
