Mainly made this to strip of parts from enemy mechs at the edges of battles, can get about 3 alpha's of with the cLPL's before overheating on a fully skilled out mech.(can switch to chain fire mode when it comes to brawling to avoid ghost heat) cUAC20 is there for finishing of mechs or as heat management while the mech cools down and has enough ammo for 560 potential dmg (28 shots/bursts), use mainly as a backup weapon or for high alpha dmg (79 dmg with double tap) when you know everything is going to hit. Critique welcome
Looks like a fun build if hot. Have you tried trading the UAC20 for a gauss rifle? It would be cooler and would sync well with the LPLs.
I tried but lost a lot of dmg in the process, the cLPL are also very hot even when chain fired. I tried something else that is a bit closer to a brawling build, it's a bit hard to manage 3 weapon groups but you can at least output enough damage to stay competitive with the 3 cMPL and cUAC10 alone without overheating too badly.
