Career Ravenous - Coil-L Fast Stealth Sniper
Thread in 'Raven' started by Toastygawa, Aug 16, 2020.
  1. Toastygawa
    Toastygawa Active Member
    52
    The Raven grants stealth to your lance, with limitations. It offers little tonnage with which to play, but it so happens that a COIL-L just fits in its right arm. This, paired with a rangefinder, lets you keep your stealth from being broken by brawlers while you use the light mech's mobility to strike with damage ranging well outside its normal armament. Zig-zagging across the engagement zone on approach, with a mechwarrior boasting high Pilot and Gunnery specializations is most effective. High Gunnery paired with Tactics is also useful, letting you Sensor Lock an enemy while cooling down.
    Note: the Heat Efficiency rating is odd with a COIL weapon, since firing it with high Evasion will spike that heat on every shot.
    Adjustments: If you haven't found or purchased a COIL yet, an ER L Laser or a pair of ER M Lasers could work, though with less maximum damage potential. An LL works (with no heat buildup per turn), if you sacrifice the JJs or a ton of armor.
    Pros: More survivable than stock, , left arm/side can offer light shield, ECM ability is better protected at distance, and the COIL-L can core out many mechs with precision.
    Cons: Still light on armor, no mid-range or close weapons, easy to overheat, 2JJs offer only limited benefit. Also, no guarantee you can line up shots at long-range or maintain distance in urban maps. Requires DLC.
  2. Toastygawa
    52
    I forgot to mention: a Rangefinder is almost essential for this mech to snipe while maintaining safe distance. Again, urban maps provide so much obstruction that the benefit is very angle-specific.
    Here's a Lostech-enhanced adjustment, sacrificing the JJs to make room for 1 HS (D), which is absolutely worth it for most maps.
