1. Hi everyone!
  2. Welcome to MechSpecs!
    --Cheers, the MechSpecs Team.
Rifleman Stats Update
Discussion in 'MWO News and Information' started by The Verge, Feb 14, 2016.
  1. The Verge
    4,348
    490
    221
    Greetings MechWarriors,
    This post contains information for all variants of the Rifleman, releasing for eligible pilots with the February 16th patch.
    RIFLEMAN
    Release date for MC: May 3rd 2016
    Release date for C-Bills: June 7th 2016
    A truly ancient BattleMech design, the Rifleman debuted before the Star League in 2505. Several variants attempted to redress some of the original’s design flaws. The RFL-3N received widespread acceptance and was heavily produced for the Star League Defense Force.
    Rifleman RFL-LK 'Legend Killer'
    The RFL-LK is the Hero variant of the Rifleman, and until its in-game MC purchase release date on May 3rd 2016 is only available through direct purchase from the Rifleman page. It features a custom 'Legend Killer' Hero Pattern and a 30% boost to C-Bill earnings.
    • Tonnage: 60
    • Engine: 240 XL
      • Top Speed: 64.8 kph
      • Max Engine Rating: 290
    • Torso Movement:
      • 100 degrees to each side.
      • 20 degrees up and down.
    • Arm Movement:
      • 0 degrees to each side.
      • 50 degrees up and down.
    • Armor: 256 (Standard)
    • Internal Structure: Endo-Steel
    • Weapons & Equipment:
      • Left Arm: Large Laser, LB 10-X AC
      • Left Torso: Medium Laser
      • Center Torso: Engine, LB 10-X AC Ammo x2
      • Right Torso: Medium Laser, LB 10-X Ammo, Double Heat Sink
      • Right Arm: Large Laser, LB 10-X AC
    • Hardpoints:
      • Left Arm: 1 Energy, 2 Ballistic
        • Lower Arm Actuator: No
        • Hand Actuator: No
      • Left Torso: 1 Energy
      • Center Torso: 1 AMS
      • Right Torso: 1 Energy
      • Right Arm: 1 Energy, 2 Ballistic
        • Hand Actuator: No
    • Heat Sinks: 10 Double
    • Jump Jets: 0 (0 Max)
    • ECM Capable?: No
    • MASC Capable?: No
    • Module Slots:
      • Mech: 1
      • Consumable: 2
      • Weapon: 2
    • Movement Archetype: Medium
    • Quirks:
      • +10 Additional Structure (CT)
      • +7 Additional Structure (LT)
      • +7 Additional Structure (RT)
      • +5 Additional Structure (LA)
      • +5 Additional Structure (RA)
      • +7 Additional Structure (LL)
      • +7 Additional Structure (RL)
      • +15% Ballistic Cooldown
      • +10% Energy Cooldown
      • -5% Energy Heat Generation
      • -10% Laser Duration
      • +10% LB 10-X Cooldown
      • -10% LB 10-X Spread
    • 30% C-Bill bonus
    • Rifleman RFL-3N
    • The RFL-3N (S) is a Special version of the RFL-3N, and features a custom Classic IS Collection Pattern and a 30% C-Bill Boost to C-Bill earnings. It is only available through the Rifleman Collector Pack.
      • Tonnage: 60
      • Engine: 240 Standard
      • Torso Movement:
        • 120 degrees to each side.
      • Arm Movement:
      • Armor: 240 (Standard)
      • Internal Structure: Standard
        • Left Arm: Large Laser, AC/5
        • Center Torso: Engine, AC/5 Ammo
        • Right Arm: Large Laser, AC/5
        • Left Leg: Heat Sink
        • Right Leg: Heat Sink
      • Hardpoints:
        • Left Arm: 1 Energy, 1 Ballistic
          • Hand Actuator: No
        • Left Torso: 2 Energy
        • Right Torso: 2 Energy
        • Right Arm: 1 Energy, 1 Ballistic
          • Hand Actuator: No
      • Heat Sinks: 10 Single
      • ECM Capable?: No
      • MASC Capable?: No
      • Module Slots:
        • Mech: 1
        • Consumable: 2
        • Weapon: 2
      • Quirks:
        • +50% Acceleration Rate
        • +50% Deceleration Rate
        • +35% Turn Rate
        • +45% Torso Turn Rate (Yaw)
        • +40% Ballistic Velocity
        • +20% Ballistic Cooldown
        • +10% Energy Range
        • +5% AC/5 Cooldown
      • 30% C-Bill bonus
    • Rifleman RFL-3N
    • The RFL-3N is the standard version of the RFL-3N (S). It does not possess the 30% C-Bill boost or the custom Pattern of its (S)counterpart. The Quirks are identical to the RFL-3N (S) above.
      [*]Rifleman RFL-3C
      • Tonnage: 60
      • Torso Movement:
      • Arm Movement:
      • Armor: 272 (Standard)
        • Left Arm: AC/10
        • Left Torso: Medium Laser, Heat Sink
        • Right Torso: Medium Laser, AC/10 Ammo x2
        • Right Arm: AC/10
      • Hardpoints:
        • Left Arm: 2 Ballistic
          • Hand Actuator: No
        • Right Arm: 2 Ballistic
          • Hand Actuator: No
      • ECM Capable?: No
      • MASC Capable?: No
      • Module Slots:
        • Mech: 1
        • Consumable: 2
        • Weapon: 2
      • Quirks:
        • +50% Accleration Rate
        • +7 Additional Strucutre (LT)
        • +10 Additional Structure (LA)
        • +10 Additional Structure (RA)
        • +25% Torso Turn Rate (Yaw)
        • +20% Ballistic Range
        • +10& Ballistic Velocity
        • +10% Ballistic Cooldown
        • -5% Medium Laser Heat Generation
      [*]Rifleman RFL-5D
      • Tonnage: 60
      • Engine: 240 XL
      • Torso Movement:
      • Arm Movement:
      • Armor: 288 (Standard)
        • Left Arm: Large Laser, ER PPC, Double Heat Sink
        • Left Torso: Double Heat Sink x3
        • Center Torso: Engine, Medium Laser x2
        • Right Torso: Double Heat Sink x3
        • Right Arm: Large Laser, ER PPC, Double Heat Sink
      • Hardpoints:
        • Left Arm: 3 Energy
          • Hand Actuator: No
        • Center Torso: 2 Energy
        • Right Torso: 1 AMS
        • Right Arm: 3 Energy
          • Hand Actuator: No
      • Heat Sinks: 17 Double
      • ECM Capable?: No
      • MASC Capable?: No
      • Module Slots:
        • Mech: 1
        • Consumable: 2
        • Weapon: 2
      • Quirks:
      • +70% Accleration Rate
      • +70% Deceleration Rate
      • +35% Turn Rate
      • +10% Energy Range
      • +50% PPC Velocity
      • -10% PPC Heat Generation
      Source: http://mwomercs.com/news/2016/02/1471-new-mech-details-for-16feb2016-patch
    enileph likes this.
