1. Welcome to MechSpecs!
    --Cheers, the MechSpecs Team.
Casual RVN-2X "First" (2xERPPC, 2xSL, XL255)
Discussion in 'RVN-2X' started by AlaskanShrakeMWO, Dec 6, 2017.
  1. AlaskanShrakeMWO
    AlaskanShrakeMWO New Member
    First, the efficiency looks awful in smurfy, but in reality, you're going 126 KPH, quirks + skill tree helps alleviate the lack of external heatsinks, and you're pretty far down the 'threat list' during most matches.
    Building a 2X to mesh with its quirks is surprisingly effective if you go with heat generation, cooldown, velocity in the firepower tree, cooling efficiency with the operations tree, going fast with the agility tree, and half of the survival tree focusing on armor.
    You have potent poking power with a very small profile at distance and if somebody inevitably develops a vendetta against your annoying (and deadly) Raven 2X, you can brawl in a pinch with the two small lasers acting as backup after you point-blank shoot your ERPPCs. Late game you're going to be scary with everyone opened up and clinging to survival.
    This is one of my favorite 'mechs upon just returning to the game after quitting 2 years ago!
  2. Excalibaard
    Excalibaard ComStar - First Circuit Staff Member
    3,084
    484
    189
    Welcome back to the game and welcome to MechSpecs, in that case :)
    I think ERPPCs are still too hot for me personally. The Heat is reduced by 10%, but the cooldown is reduced by 15% so in the end they have higher HPS because of the quirks if you try to use them optimally. 2LL 2ML/ERSL would be the way to go for me! For ERPPCs, I'll use the CDA-3C or PNT-10K
    AlaskanShrakeMWO and The Verge like this.
  3. AlaskanShrakeMWO
    Hey, thanks for the warm welcome back! It does run hot when you're being hunted down, but it allows you to poke and reposition which you ought to do in a light, 'cuz multi peeks = certain doom.
    With what you mentioned, I did toy around with the build a bit and replaced one ERPPC with an ERLL and added in two DHS. I'll give it a drive now!
  4. AlaskanShrakeMWO
    Result: pretty weird, doesn't sync well at all. No hit and away because of beam burn time.
  5. Excalibaard
    3,084
    484
    189
    yep, i'd suggest trying with regular PPCs or SNPPCs (If you dislike minimum range and aren't too afraid of getting close) instead, or running 2 (ER or regular) LL, but beam time increases the face time slightly. Or, change the ERSL into a DHS.
    AlaskanShrakeMWO likes this.
  6. AlaskanShrakeMWO
    Tried one heavy PPC and 3 MLs, it's a pretty good mixture IMO. Hard hitting single hits and you're fast so you can keep getting them, with 3 ML for upclose defense. 12 DHS so it runs cool.
