1. Welcome to MechSpecs!
    --Cheers, the MechSpecs Team.
SHC-B "Pot Shot" (3x cSSRM6, 2x cERML, 3x cMG, cAP)
Discussion in 'Shadow Cat Builds' started by Joe Bopper, Sep 21, 2016.
  1. Joe Bopper
    Joe Bopper Well-Known Member
    159
    • SHC (B) - "Pot Shot"
      • MK II (3x cSSRM6, 2x cERML, 3x MG, 1x cAP)
    ____________________
      • MK III (3x cSSRM6, 2x cERML, 1x cECM)
      • MK I (3x cSSRM6, 2x cERML, 1x cECM, 1x cAP)
    If you want to detect shutdown mechs, try this version with a cAP.
  2. skribs
    skribs Legendary Member
    1,622
    142
    Seeing as how CAP doesn't provide you with a counter-ECM if you have ECM equipped, I'd take CAP off of this one. That's an extra ton that can go to ammo or heat sinks.
  3. Joe Bopper
    159
    I prefer myself to use both a probe and ECM on this one; I find that the boost to sensor range, targeting data speeds (edit* what I thought was also lock on time), as well as detecting shut down enemy mechs is truly vital for this mech considering it utilizes streaks.
  4. skribs
    1,622
    142
    Okay, I can see the shut down Mechs part.
    Target info gathering =/= lock on time. As streaks are random in where they hit, knowing what is cored is of little benefit to Streaks, IMHO.
    Sensor range is unimportant when your weapons have a 360m range.
    As I said, though, I can agree with your ability to see and lock onto shut down Mechs. It's not been a priority on my ECM LRM mechs because then I use my backup lasers, but it makes sense for SSRMs.
  5. Joe Bopper
    159
    I've learned something today, skribs. Thank You. I will update this thread accordingly.
    Are there any ways to speed up lock on time for streaks or LRMS?
  6. Aylek
    2,680
    482
    167
    Advanced Target Decay.
  7. Joe Bopper
    159
    I'm sorry, I said the wrong word at first. My question is: is there any way to speed up or decrease lock on time for streaks or LRMs so you can shoot your targets quicker?
    I'm looking for streak/LRM lock, not decay. It seems this isn't possible, currently as of now.
  8. skribs
    1,622
    142
    Target Decay helps retain target so you can stay locked on when LOS breaks.
    As far as I know its the only thing that helps you lock on better with SSRMs.
    Sensor range seems nice for LRMs but you'll have a hard time hitting at 800+ meters anyway.
  9. Shock
    Shock Benefactor
    446
    151
    53
    The stats for Targeting computers says "targeting time boost" but the text says "target data." So I'm not sure which it actually helps with.
