Casual Sleipnir "Alf-Alpha" (2xHGauss, 4xERMLas, STD285)
Thread in 'Sleipnir' started by Falconium, Feb 15, 2018.
  1. Falconium
    Very basic, been done before, just noticed no-one had posted it here yet.
    It's customizable to a certain extent. You can replace the ERMLs with standard MLs, for better cooldown and heat, but considering the Gauss cooldown is long anyway, and the fact this thing is already quite cool, I personally think the extra range is worth keeping. Also, if you want to drop one laser for an extra ton of ammo, that's also an option; but the point of this build is really to hit those big alphas, so dropping firepower isn't necessarily ideal. Also, the engine size is rather arbitrary, it can be adjusted as you like to get an extra DHS, or more armor, or whatever.
    Excalibaard and Aylek like this.
  2. CarloArmato
    From my experience that 7th ton of ammo is a bit too much: you either won't last long enough to use it or that game will be such a stomp you won't run out of ammo, so you can upgrade to a slightly faster STD290
    On the other hand, your left arm has armor tonnage for a single ERML. It is true it can be used as a shield, but if you drop some armor and that ERML, you can fit 2xCASE (which enhance your survival once your side torso has been cored), and fit an even faster STD300
    If CASE does not appeal you, simply fit more armor
    invernomuto likes this.
