Enforcer ENF-5D(R) Tonnage: 50 Engine: 250 XL Top Speed: 81 kph Max Engine Rating: 325 Torso Movement: 125 degrees to each side. 20 degrees up and down. Arm Movement: 35 degrees to each side. 30 degrees up and down. Armor: 322 (Ferro-Fibrous) Internal Structure: Standard Weapons & Equipment: Left Arm: ER Large Laser Left Torso: Small Laser, Jump Jet x2 Center Torso: Jump Jet, Engine Right Torso: Jump Jet x2, LB 10-X AC Ammo, CASE Right Arm: LB 10-X AC Left Leg: Heat Sink Right Leg: Heat Sink Hardpoints: Left Arm: 1 Energy Left Torso: 2 Energy Right Torso: 1 AMS Right Arm: 2 Ballistic Heat Sinks: 12 Single Jump Jets: 5 (5 Max) ECM Capable?: No Module Slots: Mech: 1 Consumable: 2 Weapon: 2 Movement Archetype: Medium Quirks: Additional Structure (LA) +8 Additional Structure (RA) +8 Additional Structure (LL) +12 Additional Structure (RL) +12 Torso Turn Rate (Yaw) +25% Ballistic Range +10% Ballistic Velocity +10% Ballistic Cooldown +10% Laser Duration -12.5% LB 10-X Range +10% LB 10-X Velocity +10% LB 10-X Cooldown +10% 30% C-Bill bonus Panther PNT-10K(R) Tonnage: 35 Engine: 140 Standard Top Speed: 64.8 kph Max Engine Rating: 250 Torso Movement: 110 degrees to each side. 20 degrees up and down. Arm Movement: 40 degrees to each side. 30 degrees up and down. Armor: 208 (Standard) Internal Structure: Endo Steel Weapons & Equipment: Left Torso: Heat Sink x4, SRM Artemis Ammo, CASE Center Torso: SRM 4 w/ Artemis IV FCS, Engine Right Torso: Heat Sink x4 Right Arm: ER PPC Left Leg: Jump Jet x2 Right Leg: Jump Jet x2 Hardpoints: Left Torso: 1 AMS Center Torso: 2 Missile Right Torso: 1 AMS Right Arm: 2 Energy Heat Sinks: 13 Single Jump Jets: 4 (8 Max) ECM Capable?: No Module Slots: Mech: 1 Consumable: 2 Weapon: 2 Movement Archetype: Small Quirks: Acceleration Rate (Low, Med, High) +15% Deceleration Rate (Low, Med, High) +15% Turn Rate (Low, Med, High) +10% Additional Structure (RA) +12 Additional Structure (LL) +6 Additional Structure (RL) +6 Energy Cooldown +12.5% Energy Heat Generation -12.5% Missile Range +15% Missile Cooldown +15% ER PPC Velocity +40% ER PPC Cooldown +12.5% ER PPC Heat Generation -12.5% 30% C-Bill bonus Feedback Here: https://www.mechspecs.com/threads/odd-resistance-quirks.8525/#post-66355
