STK-3F "120°C" (4xMRM30, LE280)
Thread in 'STK-3F' started by dranozir, Aug 17, 2017.
  1. dranozir
  2. anamiac
    anamiac Well-Known Member
    140
    44
    I've never found the MRM 30 to be efficient. Why not bump them up to 3xMRM40? You could bring a bigger engine with the tonnage you save.
    If you're chainfiring, then it's much cooler than the MRM 30 model. If you alpha strike, you get 5.23 ghost heat, which may seem like alot, but it's only 39.73 total heat. Chain firing four MRM 30 gives you 38 heat, and alpha striking with 4xMRM30 gives you 45.98 heat. With 13 heatsinks on the MRM40 version, it's probably cooler alpha striking even with that ghost heat than the 11 heat sink MRM30 version would be chainfiring!
  3. Shock
    870
    353
    I've run the 5M with 3xMRM40 and the results have been decent and fun.
