A patient brawler or skirmish mech. The key to this build is positioning to take advantage the ATMs' optimum range. Fortunately the cMPLs compliment very well. I have shaved off a bit of head and leg armor for an additional DHS, but you can easily drop one for more ammo/armor. This build uses the Prime's Set-of-8 quirks to help the ATM cooldown and mobility a bit. Mechlab code: AR2D<5E1|6Spi0dD7|l^|6S|SCqi0bD7|SC|6S|oB|7Sr`0aD7|l^|oB|oB|l^s`0eD7|l^|oB|oB|l^ta0fD7ua0gD7v80`D7w707070
I like the look of this build, it looks like it should work nicely. I bought a TBR pack and started theorizing, and I like trying set-of-8 builds, and I also came up with this load out as a viable possibility. I also threw on the 2xMG's for kicks: _ I think for the best PRIME set-of-8 build it is a competition between this build and a 2xATM12 build: _ I'll be giving them both test runs. For a MPL/ATM combo, the TBR-A also has a set-of-8 load out: _
In the end I went with the ERSL version: _ Crazy good DPS, good heat management, sweet spot fighting range is between 130 and 310 meters. Get a battle buddy and try to not get prioritized and you can get some goood work done. Skills: https://kitlaan.gitlab.io/mwoskill/...062101cf37f0000e80e1370c40c838f0703#s=Weapons
