This is my take on the 7M. Maximum mobility, near full armor (literally 2 away from max, and those are on legs) and reasonable firepower for the heat generated. I used to run 2 SRM6s, but I've noticed I do just as well with the SRM4s. Alt Config A This is the end result of me playing around with it, after getting suggested I add a SRM2 and take off a ton of ammo. I also fiddled with armor values and dropped AMS (since LRMs are rarely used and not dangerous when they are) to pick up more DHS. Alt Config B This is going to be my redo after the BAP buff. It is essentially a light hunter. Boom boom!
Poindexter hit the nail on the head. I wanted something that would go BOOM and then I could fire the mediums. With the NARC tube I have to constantly maintain lead on the target while going FWOO FWOO FWOO FWOO.
4 tons of SRM ammo seems to be a bit excessive, maybe you can fit an SRM2 in the NARC tube, which doesn't take as long to fire the entire salvo? When I run 2 SRM4's I often use 2 tons, and only in really prolonged fights I'll use 3.
