1. Welcome to MechSpecs!
    --Cheers, the MechSpecs Team.
TDR-9S "I like living dangerously" (2x LLas, 2x AC5, XL300) + Video
Discussion in 'TDR-9S' started by Natsu, Apr 30, 2014.
  1. Natsu
    Natsu New Member
    Yo here is my 9S and a video
  2. cs_kami
    cs_kami Benefactor
    434
    Looks like a fun build. Good video, and you had a great team with you.
  3. Excalibaard
    Excalibaard ComStar - First Circuit Staff Member
    3,154
    506
    219
    I suspect that it it might have a few too much heatsinks for just 2 Large Lasers. 2 AC5s is heat neutral and should provide enough fire if you might have to cooldown on Terra Therma or something.
    That said, it's really hard to put that tonnage to use otherwise, so I suppose it's okay, you can always swap one DHS for an extra ton of ammo if necessary.
  4. Kamiko K
    Kamiko K New Member
    I just wanted to say I gave this a go, used two ER large instead and have found this build to be excellent indeed. I dropped a heatsink and a ton of ammo to fit in ams as well.
    This build can chew through mechs with surprising speed on occasion.
    I gave you a 5 star:)
  5. dog_funtom
    dog_funtom Well-Known Member
    Tried this build a bit. Hard to say anything yet, but for now looks like it's still pretty good in the current meta.
    But it too cold even with suggested by Kamiko K ERLLas and -1 DHS. I have to much heat discipline. So, minmaxing shall be continued!
    P.S.: I don't like how there is so little attention to this build, so I'll give it 5/5 for now. Don't promise that I'll not change it later.
  6. skribs
    skribs Legendary Member
    1,622
    142
    Nice mid-range DPS build. I'd probably put ER-LL on, and put them both in the right torso, but I wouldn't take off DHS for AMS.
  7. skribs
    1,622
    142
    Yep, 2x ERLL in the right torso for the high mount, 2x AC5 in the left arm. Wish I could mount those higher, but oh well.
    This thing is surprisingly good at killing Locusts, of all things.
