1. Hi everyone!
  2. Welcome to MechSpecs!
    --Cheers, the MechSpecs Team.
USER BUILD: Grimm's JM6-DD Jagermech "Flak Gun"
Discussion in 'Mech Build and System Tests' started by Michael, Aug 28, 2013.
  1. Michael
    https://mwo.smurfy-net.de/mechlab#i=65&l=79bc0aed4400b0d0e119fb0897f26ed82898dabd
    A lot of guys are/were (after the heat nerf this is kinda hard to do) running around with their 6x AC2 crazy insane dakka dakka builds. I decided to scale it down a little bit and run with just a macro fed 4x AC2 build. I call it the Flak Gun. The entire purpose behind this mech is to lay down suppressing fire, assisting with kills where you can but not necessarily as a primary front line unit.
    http://www.youtube.com/watch?v=9IV4lO1iSYw
    [size=8pt]NOTE: There is currently a bug with AC2s that make it tricky to macro them. If you fire 4x AC2 within .5 seconds or more then you have an enormous heat penalty after about 50% but if you fire all 4 in under .5 seconds it doesn't seem to add the penalty. I will make a macro instruction video for this mech in the coming days.
