1. Hi everyone!
  2. Welcome to MechSpecs!
    --Cheers, the MechSpecs Team.
USER BUILD: IanSane's STK-3F "Alpha Much?"
Discussion in 'Mech Build and System Tests' started by Michael, Nov 22, 2013.
  1. Michael
    https://mwo.smurfy-net.de/mechlab#i=47&l=69ca1d4d41886bd75cb1db6c7a98e3da8b56932c
    http://www.youtube.com/watch?v=psCehJdu10U
    This mech was originally posted by IanSane, who also did the combat drop video.
    RECOMMENDED ROLE: Heavyweight Brawler
    TOTAL PRICE: 13,042,480 (Standard Engines are cheap cheap)
    DIFFICULTY LEVEL: WARNING!! EXTREME HEAT DISCIPLINE REQUIRED
    STRENGTHS:
    • Incredibly high alpha strike (88.0)
    • Covers most ranges well as long as you use the weapons at their designed ranges
    • Standard engine increases your survivability during brawls
    • Relatively cheap to assemble in terms of assault mechs due to standard engine
    • Can obliterate most light mechs with a single SRM6 volley if you can clip them
    DRAWBACKS:
    • Can run hotter than the sun if you rely on the PPCs for brawling
    • Requires extreme heat discipline and steep learning curve to pilot this mech well
    • Fairly slow and can get left behind if you aren't paying attention in PUGs
    This build can be discussed here: IanSane's Alpha Much?
