With the unlocked CT hardpoint you can now run a typical clan energy vomit combination. Will run VERY hot, but at least it has a high alpha. Will probably only work for CW as an early game trader. B torso omnipods for energy heat generation D left arm for energy duration B arm for energy cooldown (not really needed) Prime Legs for acceleration/deceleration quirks to help peek faster
4/5, Performs ok, i believe the added tonnage spent on LPLs which can then not be spent on more cooling makes it the best laservomit setup, but still works. You do get slightly lower burn-time
